Are they modern, repro carpets? Do they have loops of webbing sewn to the carpet edge to hold the clips? If so, then it’s the position of those webbing loops that will determine where any corresponding holes in the chassis need to be – and not necessarily the exact same places as with the original carpet.Those holes. yes they are self tappers. The holes are less than an inch up from the floor surface and hard to spot. Impossible if the vertical carpet is already on. Size. the screws are quite chunky. maybe for a4mm screw but more likely 3mm. Start with a larger screw and – if too tight – use a smaller screw.
