was it ever working properly? Couple of thoughts – but that’s all they are….
Sometimes a temp warning sensor gets fitted (wrong part) when a replacement temp. sensor is needed. I don’t know if the thread sizes on a DS and if that’s possible.
On non-EFI cars, that had a temp. gauge, the sensor was on the lower side of the water pump back housing. Those cars (from 1970 at least) had the sender for the big red warning light on the side of the cylinder head. But on later EFI cars (post July 72) I think the big red warning light sender to the under-water pump position, and had their temp. gauge sender in a new position on the side of the cylinder (i think)
So have you got the right sender/ sensor wired up to your dashboard? is it possible that you have two panic senders fitted and wired in? You wouldn’t be the first!
Well done. Looks lovely. That’s a BIG change from when you first had that non-running ambulance trailered over from France all those years ago.
I used the tool you made to fit my parking brake springs. It really did make the job easy and – most importantly – risk free!
https://ds-restoration.blogspot.com/2023/07/fitting-parking-brake-cable-and-springs.html
Let us know how you get on.
Hello Chris and welcome
As with Rob, the ‘Nuancierds’ is a frequent go-to site for me.The Pallas question is a tricky one. Just about all the parts that distinguished a pallas from a standard DS are either being re-manufactured, or can be bought secondhand.
19th January 2025 at 1:24 pm in reply to: On Line Restoration of Paul’s ’68 Pallas – some help please ? #10500here is a ‘WeTransfer’ link to some more photos showing the brake pipe routing (although i also have photos showing minor variations).
Grab these while you can. The link will die in 3 or 4 days time.
