Viewing 15 posts - 1 through 15 (of 1,438 total)
  • in reply to: Nearly There! #13944
    Thanks Peter. I know you’ve done this – so it can work – but that adaptors confusing me. To screw into a D block, the male end needs to be M10 x 1.5 pitch and the female end some more common size of switch.
    What does Jamie do?
    What a load of old SH!T!
