Where as previously there was only an ID19, in 1969 Citroen added an ID20 alongside the ID19. Both were manual four speeds with the same 1985cc engines, except that the ID20 had slightly better trim and was tuned to give a few more BHP.
For the 1970 year, the cars were renamed. the ID19 became the DSpecial and the ID20 became a DSuper.
After a year or so, Citroen offered an extra fifth gear for the D Super – so there were SOME 1985cc cars that were DSuper (5)s. The DS21 (2175cc) could be bought with a manual 5 speed box.
Then in 72 or maybe 73, the DS21 was dropped from the Ds range and instead resurrected as part of the ID range – where it became the 2175cc ‘DSuper 5’. Sounds like the St.Albans car is a standard 1985cc 4 speed DSuper. Chassis tags still said ‘ID20’. All perfectly legit. It may not be a ‘DSuper5’. but it’s still a step above a DSpecial and from what Julian has said, might be worth haggling over.
