Not sure I understand what you mean there Sean?
I’ve got split spheres with removable dampers – the kind that can be dismantled. Providing (a) you get the right shims and (b) you know what shim combinations to use, you can alter the behaviour of the spheres.
Hi Ralph
To put up a photo here, you need to have the photo hosted somewhere else – then provide a link to it here.i have a free account with ImgBB. I put the image up there and embed the code as ‘BBcode full linked’, then simply copy the code created and paste it in to any post here.
John
Are you grappling with your ignition/ starting wiring yet? I feel we have done this before? But these drawings might help. Both are for RHD cars (though in terms of the starter/ ignition there isn’t really any difference with LHD).This first one shows the key-operated starter. The dotted line from the key unit (listed as parts of ’47’) goes all the way over towards the battery side of the drawing as the key unit has an extra pair of contacts for starting the car. (Those extra contacts are shown as separate part 32 in the drawing). Turning the key closes the contacts of/ at 32 and current flows down to the starter motor and solenoid – shown as part 11.
Hi Steve
ANOTHER fader-related question if I may…As well as having an ancient Continental Edison radio, I have bought a discrete Bluetooth receiver and amp to fit to my DS.The radio will go through the equally ancient front/ rear fader control that came with it. I’ve had to buy a new 4 ohm front speaker and anticipate buying a 4 ohm rear speaker. i plan to add 1 ohm resistors in series to both, so that they then have the 5 ohm resistance specified by/ expected by my radio. I’m assuming that my fader control is also designed for an expected 5 ohm resistance (values of the fader resistors are in a photo in my earlier post).
*Channel: 2
*Voltage Supply: DC12V
*Rated Input Current: 3A
*RMS Power: 500W
*Output Impedance: 4-8R
*Output power: 2x18W
*The Signal Level: 200MV 47Kfront speaker is the one from ‘ChromeLondon – it’s the only one i could find of the correct size. 4 ohms and claims to be 40 watts. Not bought a rear speaker yet.
Hope you can advise!
I’m often startled by the amount of water you sometimes see during from a car exhaust – but i’m confident it’s a natural process. The D exhaust is level until it reaches the back box then the tail pipes point upwards under the boot until they terminate. Condensation gathers at the back box and only burbles out occasionally, or when the car is pointed up a slope.
As Peter says, exhausts rot out because of the condensation sitting in them. This is particularly so of the back box which runs cooler than the front box. The front box evaporates away any condensation. and it probably migrates to the back box/ pipes.
