Viewing 15 posts - 1 through 15 (of 951 total)
  • in reply to: Two years to go, possibly #10661
    Well done. Looks lovely. That’s a BIG change from when you first had that non-running ambulance trailered over from France all those years ago.
    in reply to: Two years to go, possibly #10657
    I used the tool you made to fit my parking brake springs. It really did make the job easy and – most importantly – risk free!
    https://ds-restoration.blogspot.com/2023/07/fitting-parking-brake-cable-and-springs.html
    in reply to: Hello from Wiltshire #10624
    in reply to: Rear Screen Heater #10619
    in reply to: Rear Screen Heater #10616
    in reply to: Rear Screen Heater #10611
    in reply to: Hello from Wiltshire #10608
    Let us know how you get on.
    in reply to: Hello from Wiltshire #10605
    Hello Chris and welcome
    As with Rob, the ‘Nuancierds’ is a frequent go-to site for me.
    The Pallas question is a tricky one. Just about all the parts that distinguished a pallas from a standard DS are either being re-manufactured, or can be bought secondhand.
    in reply to: Two years to go, possibly #10583
    in reply to: Two years to go, possibly #10580
    in reply to: LHM Reservoir Transfer Instructions ? #10578
    in reply to: LHM Reservoir Transfer Instructions ? #10575
    This is the same engine bay a few moments before those stickers were added. Amazing what a few stickers can do.It almost looks like a different car………
    free photo content[/url]
    in reply to: LHM Reservoir Transfer Instructions ? #10572
    So this isn’t yours then Peter?
    free picture hosting sites[/url]
    here is a ‘WeTransfer’ link to some more photos showing the brake pipe routing (although i also have photos showing minor variations).
    Grab these while you can. The link will die in 3 or 4 days time.
    https://we.tl/t-BqTUshPWtK
    From previous posts it looks as though you describe your car as being the same as mine – a 1968 DS21 bvh (hydraulic gearbox). my only query is that in a previous post you say you have a ‘DY’ engine, which would have started life as 1985cc. Anyway, let me assume your car is a 1968 BVH car….
    This first diagram here shows how the pipes fit the calipers on a
      bvh
    car.
    The pipe that goes from the LHS caliper to the accelerated idling control is fixed to the side of the engine – where the pressure regulator is, and at several other points along the way.
    the pipe that goes to the centrifugal regulator goes over the bell housing and then straight up the bracket between HP pump and centrifugal regulator.
    At their caliper ends, both pipes are fixed to the top of their respective calipers, then loop AROUND the outside of the parking brake mechanisms before continuing their journeys. I could maybe provide photos of these routes.
    The second image here is from a later parts catalogue. caliper connections are the same. the only difference is in the routing and splitting leading to the calipers.
