Viewing 15 posts - 1 through 15 (of 1,444 total)
  • in reply to: Hello from Wiltshire #13967
    They are various versions on Ebay France, but I found mine in the UK.
    Like you, I’m going to be selective about what i tasks I tackle over the winter as i don’t want to inadvertently delay being able to get it back out on the road in Spring. Top are the list are the oil pressure switch and a carb swap.
    in reply to: Hello from Wiltshire #13964
    in reply to: Nearly There! #13962
    in reply to: Nearly There! #13960
    in reply to: Nearly There! #13948
    What does Jamie do?
    What a load of old SH!T!
