Viewing 15 posts - 1 through 15 (of 1,322 total)
  • in reply to: reconstructive surgery #12976
    in reply to: Bonnet repairs #12974
    in reply to: Front/Rear Loudspeaker fader control #12972
    in reply to: Front/Rear Loudspeaker fader control #12966
    in reply to: Front/Rear Loudspeaker fader control #12963
    in reply to: Sh*t Just Got Real….. #12956
    in reply to: Hello from Wiltshire #12901
    in reply to: Hello from Wiltshire #12897
    I feel another table coming on……
    The top table includes the 2175cc DSuper5 (‘DP’ vehicles). the bottom table is for ‘DT’ vehicles. These are the 1985cc ‘DSupers’ with the optional 5th gear.
    in reply to: Hello from Wiltshire #12895
