Still no Peter?
Some very positive progress!
Garage envy again…..
I’m not sure what bit you are calling the ‘sill embellishers’. We also use different terminology:) Do you mean the bits right down below the sill – visible even when the doors are closed, or do you mean the square-patterned bits on the sills inside the doors?I suspect it was a requirement that some parts of cars sold by Citroen in SA were made locally. I don’t know the history well enough. I know tat SA cars had different hub caps and (i think?) different door handles for example.
