Viewing 15 posts - 1 through 15 (of 1,326 total)
  • in reply to: Hello from Wiltshire #13007
    I’m not sure what bit you are calling the ‘sill embellishers’. We also use different terminology:) Do you mean the bits right down below the sill – visible even when the doors are closed, or do you mean the square-patterned bits on the sills inside the doors?
    I suspect it was a requirement that some parts of cars sold by Citroen in SA were made locally. I don’t know the history well enough. I know tat SA cars had different hub caps and (i think?) different door handles for example.
    in reply to: reconstructive surgery #12984
    in reply to: reconstructive surgery #12982
    in reply to: reconstructive surgery #12978
    in reply to: reconstructive surgery #12976
    in reply to: Bonnet repairs #12974
    in reply to: Front/Rear Loudspeaker fader control #12972
    in reply to: Front/Rear Loudspeaker fader control #12966
    in reply to: Front/Rear Loudspeaker fader control #12963
    in reply to: Sh*t Just Got Real….. #12956
