Viewing 15 posts - 1 through 15 (of 1,446 total)
  • in reply to: Hello from Wiltshire #13974
    While that stuff is a bugger to get off – very springy – it’s also easily damaged. If you apply too much leverage to the trim you ‘dink’ it. And then no amount of reshaping is going to restore how the light falls on it. It will always look not *quite* right….Oh. And it’s also razor sharp.
    I think that having got it going, I used two wide flat house decorating scrapers that had thin flat blades to lever it off, working them in tandem.
    in reply to: Hello from Wiltshire #13969
    28 and 26 are ‘keyed’ together: 28 is used to tighten 26 into the handle (8). As such, 27 (a slotted washer) is essential for holding part 28 low on 26 – whilst leaving the threaded part exposed to catch the handle.
    If you find you have more missing, you might find a thin shim washer of the right size and could just cut a slit.
    You’ll find that rear doors have part 33 screwed to them. Front doors have part 32. it’s a carrier for the long rod.
    If you are doing one door at a time it shouldn’t be an issue, but be aware that the lock parts (part 2) are different for front and rear doors. Not easy to spot. The difference enables the rear doors to be locked from inside so that the button on the outside can’t open the door. To stop the from doors being opened from the outside you should need to use the key.
    in reply to: Hello from Wiltshire #13967
    They are various versions on Ebay France, but I found mine in the UK.
    Like you, I’m going to be selective about what i tasks I tackle over the winter as i don’t want to inadvertently delay being able to get it back out on the road in Spring. Top are the list are the oil pressure switch and a carb swap.
    in reply to: Hello from Wiltshire #13964
    in reply to: Nearly There! #13962
    in reply to: Nearly There! #13960
    in reply to: Nearly There! #13948
    What does Jamie do?
    What a load of old SH!T!
