They are various versions on Ebay France, but I found mine in the UK.
Like you, I’m going to be selective about what i tasks I tackle over the winter as i don’t want to inadvertently delay being able to get it back out on the road in Spring. Top are the list are the oil pressure switch and a carb swap.
The male end needs to be 1.5 pitch. Closest kind of thing i found was this – which adds an extra 15mm or so sticking out of the block.
What does Jamie do?
What a load of old SH!T!
