Viewing 15 posts - 1 through 15 (of 1,435 total)
  • in reply to: Carpet fitting #13923
    Those holes. yes they are self tappers. The holes are less than an inch up from the floor surface and hard to spot. Impossible if the vertical carpet is already on. Size. the screws are quite chunky. maybe for a4mm screw but more likely 3mm. Start with a larger screw and – if too tight – use a smaller screw.
    For the rear carets there are two holes about 4 inches in from the inner foot self and an off-centre middle hole that is closer to the LH sill than the RH. my car is a LHD car by the way.
