Viewing 15 posts - 1 through 15 (of 1,340 total)
  • in reply to: reconstructive surgery #13096
    Still no Peter?
    Some very positive progress!
    Garage envy again…..
    in reply to: Hello from Wiltshire #13030
    in reply to: reconstructive surgery #13023
    in reply to: Hello from Wiltshire #13008
    in reply to: Hello from Wiltshire #13007
    I’m not sure what bit you are calling the ‘sill embellishers’. We also use different terminology:) Do you mean the bits right down below the sill – visible even when the doors are closed, or do you mean the square-patterned bits on the sills inside the doors?
    I suspect it was a requirement that some parts of cars sold by Citroen in SA were made locally. I don’t know the history well enough. I know tat SA cars had different hub caps and (i think?) different door handles for example.
