Viewing 15 posts - 1 through 15 (of 1,321 total)
  • in reply to: Bonnet repairs #12974
    in reply to: Front/Rear Loudspeaker fader control #12972
    in reply to: Front/Rear Loudspeaker fader control #12966
    in reply to: Front/Rear Loudspeaker fader control #12963
    in reply to: Sh*t Just Got Real….. #12956
    in reply to: Hello from Wiltshire #12901
    in reply to: Hello from Wiltshire #12897
    I feel another table coming on……
    The top table includes the 2175cc DSuper5 (‘DP’ vehicles). the bottom table is for ‘DT’ vehicles. These are the 1985cc ‘DSupers’ with the optional 5th gear.
    in reply to: Hello from Wiltshire #12895
    in reply to: Hello from Wiltshire #12894
    Where as previously there was only an ID19, in 1969 Citroen added an ID20 alongside the ID19. Both were manual four speeds with the same 1985cc engines, except that the ID20 had slightly better trim and was tuned to give a few more BHP.
    For the 1970 year, the cars were renamed. the ID19 became the DSpecial and the ID20 became a DSuper.
    After a year or so, Citroen offered an extra fifth gear for the D Super – so there were SOME 1985cc cars that were DSuper (5)s. The DS21 (2175cc) could be bought with a manual 5 speed box.
    Then in 72 or maybe 73, the DS21 was dropped from the Ds range and instead resurrected as part of the ID range – where it became the 2175cc ‘DSuper 5’. Sounds like the St.Albans car is a standard 1985cc 4 speed DSuper. Chassis tags still said ‘ID20’. All perfectly legit. It may not be a ‘DSuper5’. but it’s still a step above a DSpecial and from what Julian has said, might be worth haggling over.
