Let us know how you get on.
Hello Chris and welcome
As with Rob, the ‘Nuancierds’ is a frequent go-to site for me.The Pallas question is a tricky one. Just about all the parts that distinguished a pallas from a standard DS are either being re-manufactured, or can be bought secondhand.
19th January 2025 at 1:24 pm in reply to: On Line Restoration of Paul’s ’68 Pallas – some help please ? #10500here is a ‘WeTransfer’ link to some more photos showing the brake pipe routing (although i also have photos showing minor variations).
Grab these while you can. The link will die in 3 or 4 days time.
19th January 2025 at 12:20 pm in reply to: On Line Restoration of Paul’s ’68 Pallas – some help please ? #10499From previous posts it looks as though you describe your car as being the same as mine – a 1968 DS21 bvh (hydraulic gearbox). my only query is that in a previous post you say you have a ‘DY’ engine, which would have started life as 1985cc. Anyway, let me assume your car is a 1968 BVH car….
This first diagram here shows how the pipes fit the calipers on a
- bvh
car.
The pipe that goes from the LHS caliper to the accelerated idling control is fixed to the side of the engine – where the pressure regulator is, and at several other points along the way.
the pipe that goes to the centrifugal regulator goes over the bell housing and then straight up the bracket between HP pump and centrifugal regulator.
At their caliper ends, both pipes are fixed to the top of their respective calipers, then loop AROUND the outside of the parking brake mechanisms before continuing their journeys. I could maybe provide photos of these routes.
The second image here is from a later parts catalogue. caliper connections are the same. the only difference is in the routing and splitting leading to the calipers.
19th January 2025 at 9:11 am in reply to: On Line Restoration of Paul’s ’68 Pallas – some help please ? #10498Thank you for your very, VERY kind words. The blog was started partly because it provided a use for the many reference photos i was taking. but the main reason was to try to encourage others to get stuck in and keep these lovely old cars going of course.
Brake pipes….There were different configurations of piping for bvh cars and manual cars. On a bvh car, the right front brake is bled up on the centrifugal regulator and the left brake is bled up by the carburettor(!) That affects how the pipes are connected to the brake calibers. I have photos for my 68 car, but I also have a couple of pictures of how they are fitted and will dig them out after i’ve walked the dog!
What is your car Michael? bvh or manual gear change?
I suspect the green colour was to clearly distinguish it from the previous red LHS. For the first couple of years after switching to LHM, new cars had a BIG label on the (green) reservoir to remind owners/ garages to top up with LHM and not LHS.
