Viewing 15 posts - 1 through 15 (of 1,289 total)
  • in reply to: Ds pallas 1972 Comfort ride spheres #12700
    Not sure I understand what you mean there Sean?
    in reply to: Ds pallas 1972 Comfort ride spheres #12698
    I’ve got split spheres with removable dampers – the kind that can be dismantled. Providing (a) you get the right shims and (b) you know what shim combinations to use, you can alter the behaviour of the spheres.
    in reply to: Ds pallas 1972 Comfort ride spheres #12693
    in reply to: external wind deflector #12249
    in reply to: external wind deflector #12247
    Hi Ralph
    To put up a photo here, you need to have the photo hosted somewhere else – then provide a link to it here.
    i have a free account with ImgBB. I put the image up there and embed the code as ‘BBcode full linked’, then simply copy the code created and paste it in to any post here.
    in reply to: Piston & Liner Replacement Shortcut ? #12245
    in reply to: Loom wire gauges #12242
    John
    Are you grappling with your ignition/ starting wiring yet? I feel we have done this before? But these drawings might help. Both are for RHD cars (though in terms of the starter/ ignition there isn’t really any difference with LHD).
    This first one shows the key-operated starter. The dotted line from the key unit (listed as parts of ’47’) goes all the way over towards the battery side of the drawing as the key unit has an extra pair of contacts for starting the car. (Those extra contacts are shown as separate part 32 in the drawing). Turning the key closes the contacts of/ at 32 and current flows down to the starter motor and solenoid – shown as part 11.
    in reply to: Loom wire gauges #12240
    in reply to: external wind deflector #12238
    My Webasto has a flimsy green spring=loaded thing that tips up as the roof is opened
    But I’ve also seen far more substantial fold-up screens on Ds. This photo is from Citroen Classics.
    Of course it is only of use when the roof is open. is that when you have your noise problem – or when it’s closed?
    in reply to: external wind deflector #12236
    in reply to: external wind deflector #12235
    in reply to: Front/Rear Loudspeaker fader control #12228
    Hi Steve
    ANOTHER fader-related question if I may…As well as having an ancient Continental Edison radio, I have bought a discrete Bluetooth receiver and amp to fit to my DS.
    The radio will go through the equally ancient front/ rear fader control that came with it. I’ve had to buy a new 4 ohm front speaker and anticipate buying a 4 ohm rear speaker. i plan to add 1 ohm resistors in series to both, so that they then have the 5 ohm resistance specified by/ expected by my radio. I’m assuming that my fader control is also designed for an expected 5 ohm resistance (values of the fader resistors are in a photo in my earlier post).
    *Channel: 2
    *Voltage Supply: DC12V
    *Rated Input Current: 3A
    *RMS Power: 500W
    *Output Impedance: 4-8R
    *Output power: 2x18W
    *The Signal Level: 200MV 47K
    front speaker is the one from ‘ChromeLondon – it’s the only one i could find of the correct size. 4 ohms and claims to be 40 watts. Not bought a rear speaker yet.
    Hope you can advise!
    in reply to: Light pods in wings ? #12226
    in reply to: Wiring and Dashboard #12225
    Thank you. Here’s a scary ‘before’ photo from 2016. The car had been off the road for 16 years at that point – so 26 now. That’s nearly half it’s lifetime
    in reply to: Exhaust dumping excessive water #12219
    I’m often startled by the amount of water you sometimes see during from a car exhaust – but i’m confident it’s a natural process. The D exhaust is level until it reaches the back box then the tail pipes point upwards under the boot until they terminate. Condensation gathers at the back box and only burbles out occasionally, or when the car is pointed up a slope.
    As Peter says, exhausts rot out because of the condensation sitting in them. This is particularly so of the back box which runs cooler than the front box. The front box evaporates away any condensation. and it probably migrates to the back box/ pipes.
