I don’t have an EFI and don’t have the same dashboard warning lights as you – so a lot of this is guesswork…..
I think the two senders/ sensors you have on the side of your cylinder head are both specific to the Bosch EFI computer – between cylinders 3 and 4 is a cold start sensor. Between cylinders 1 and 2 – sticking out on an extension – is a thermal sensor (for the EFI computer). This has a two prong push in socket.
But if that is so, then the sender in your water pump should be the one that triggers the big red ‘STOP” light when the car overheats. And you say it’s not connected? That light can also come on because of brake and oil pressure i think as it’s also connected to those sensors. As a result, itwill probably come on when you initially start the car (low hydraulic pressure). But did it did it actually come on when the car was running and over-heated?
Getting back to your temp gauge sensor…
I think that in your case ( a post August 72 EFI?? – so a 73 or 74 model), the general engine temperature sensor might be fitted to the “supplementary air control” on the block near the oil dipstick. Is there a sensor sticking out of the end of that and is it wired in?So you might find you have TWO senders/ sensors that are not plugged in and the next problem will be to find where their wires are! The temp gauge goes into the yellow multiple on the back of the speedo/ gauge unit. Check that you have a wire in the multiplex. No wire, no needle movement. If your temp gauge is original to the car, there should be a little white thermometer symbol printed on its clear plastic face. and there should be a wire in the plug.
was it ever working properly? Couple of thoughts – but that’s all they are….
Sometimes a temp warning sensor gets fitted (wrong part) when a replacement temp. sensor is needed. I don’t know if the thread sizes on a DS and if that’s possible.
On non-EFI cars, that had a temp. gauge, the sensor was on the lower side of the water pump back housing. Those cars (from 1970 at least) had the sender for the big red warning light on the side of the cylinder head. But on later EFI cars (post July 72) I think the big red warning light sender to the under-water pump position, and had their temp. gauge sender in a new position on the side of the cylinder (i think)
So have you got the right sender/ sensor wired up to your dashboard? is it possible that you have two panic senders fitted and wired in? You wouldn’t be the first!
Well done. Looks lovely. That’s a BIG change from when you first had that non-running ambulance trailered over from France all those years ago.
I used the tool you made to fit my parking brake springs. It really did make the job easy and – most importantly – risk free!
https://ds-restoration.blogspot.com/2023/07/fitting-parking-brake-cable-and-springs.html
Let us know how you get on.
Hello Chris and welcome
As with Rob, the ‘Nuancierds’ is a frequent go-to site for me.The Pallas question is a tricky one. Just about all the parts that distinguished a pallas from a standard DS are either being re-manufactured, or can be bought secondhand.
