Where as previously there was only an ID19, in 1969 Citroen added an ID20 alongside the ID19. Both were manual four speeds with the same 1985cc engines, except that the ID20 had slightly better trim and was tuned to give a few more BHP.
For the 1970 year, the cars were renamed. the ID19 became the DSpecial and the ID20 became a DSuper.
After a year or so, Citroen offered an extra fifth gear for the D Super – so there were SOME 1985cc cars that were DSuper (5)s. The DS21 (2175cc) could be bought with a manual 5 speed box.
Then in 72 or maybe 73, the DS21 was dropped from the Ds range and instead resurrected as part of the ID range – where it became the 2175cc ‘DSuper 5’. Sounds like the St.Albans car is a standard 1985cc 4 speed DSuper. Chassis tags still said ‘ID20’. All perfectly legit. It may not be a ‘DSuper5’. but it’s still a step above a DSpecial and from what Julian has said, might be worth haggling over.
My cars a bvh, but if it was manual i wouldn’t carry a spare clutch cable up in the roof channel.
Fitting a clutch cable is maybe a couple of hours work. Refitting the b*stard Pallas roof trim is about four!
If it helps….
These are four photos by Stuart McGregor that go with the text in the post above – which I repeat here. You can also find a good exploded diagram of the parts in drawing number 2-142/1 in the early pages of manual 648.
As Stuart wrote:
From the bottom you’ll have to undo the pinch bolt on the lever (this is a reference to the bolt through part 7 in the drawing) and pry the lever off the pedal shaft (part 1 in the drawing)…….
…..to get to the split pin/clevis pin (Stuarts photo above shows some kind of knotted or tangled wire?) that secures the cable inner at the bottom end.
Then from the top you need to remove the pozidrive screw that holds the clamp plate (part 5?) holding the outer in place. (near to the engine mount bolt).
With that done remove the clamp plate and the outer will lift out.
A telescopic magnetic picker may be your friend here! There’s a pic that shows that upper part disassembled if that helps.Getting that small clamp plate (part 5) in position and fixed on reassembly will most likely be your biggest challenge. You may be best to remove a few items that obscure it. Perhaps the weight fixed to the bulkhead and the engine mount? (In a later post Stuart said it may not be as bad as he thought and that a LONG screwdriver could be used to access the screw).
Have included a pic that includes these two items (the phots above), though appreciate that there’s a lot of EFI hardware etc also sitting above this area.
I recall a VERY long thread about this (throttle cable replacement on a LHD efi car) on another forum: the largely (though not exclusively) American ‘CitroenDSID’ group on a platform called ‘IO’. You could do a lot worse than seeking out that thread (and joining the forum if you really, really need to).
This is the thread though i’m not sure you will be able to access it. The thread was called “Oh, Snap!!!”
https://groups.io/g/CitroenDSID/topic/94635675#msg96040
It was 82 posts long (!) and in early posts advice included:
From Michael Faulks
“access is tight but it can be replaced without taking the engine out. There is a clamp just above the pulley that holds the sheath and a slot in the bracket so the cable can be threaded onto the pulley. Undo the clamp and the adjuster bracket then the cable just pulls out of the engine bay.And from Stuart McGregor:
“Here’s a few more pix that show the stages below.From the bottom you’ll have to undo the pinch bolt on the lever and pry the lever off the pedal shaft to get to the split pin/clevis pin that secures the cable inner at the bottom end.
Then from the top you need to remove the pozi screw that holds the clamp plate holding the outer in place. With that done remove the clamp plate and the outer will lift out. A telescopic magnetic picker may be your friend here! There’s a pic that shows that upper part disassembled if that helps.
Getting that small clamp plate in position and fixed on reassembly will most likely be your biggest challenge. You may be best to remove a few items that obscure it. Perhaps the weight fixed to the bulkhead and the engine mount? Have included a pic that includes these two items, though appreciate that there’s a lot of EFI hardware etc also sitting above this area. It’s difficult to figure that out as I don’t have an engine in my car!”
As a South African car, they followed their own trim specification and names. The advert says it 2100cc but a DS20/5 was a 1985cc DY3 engine with a five speed box.
https://www.citroenet.org.uk/publicity-brochures/ds/za/za-ds.html
So a bit/ lot like the ‘DSuper(5)’ (a 1985cc DSuper but with an extra gear) but NOT like the ‘DSuper5’ (2175cc engine and an extra gear).
The photos show a head rebuild, maybe the pots were upgraded from 1985cc but that would make it 2175cc not 2100cc?
From the description, ownership and willingness to show photos, this might not be a bad car – but the price certainly reflects that. And be aware that it’s not just European cars: South African cars can have rust too 🙂
Get yourself a good dSuper 5 and i think you’ll find it a keeper. Prior to 1973, it was a badged as a Ds21 5 speed manual but they are virtually the same thing.
Not cars i’d suggest you entertain, but I had THREE barn finds at the weekend! Last June I’d run past someone’s house in a local village early one morning and spotted a white DS on a drive. i went back and took a photo and put a note through the door but heard nothing.
On sunday (12 months later!) the owner texted me out of the blue asking for advice and a possible value.
The white car under a car cover turned out to be a LHD 1969 ID20. It had obvious rot around the front top of the screen which you have to assume will be found to be much worse when you inevitably take the roof off. (You can see it in the photo above). Sure enough there had been water in the footwells and the drivers footwell floor was rotted (you could see the ground through it) though the inner sills seemed okay. there were some signs of minor rust in the boot but the floor looked solid. i couldn’t get behind the panel that covers the torsion bar. the gutters along the sides of the boot seemed very tidy whereas i’d expected rust. I couldn’t see the underside of the car or exhaust. Money had been spent on the car a few years ago over at the Chevronics Centre including a new alternator and other engine work. They had also said it might need a head gasket replacement. Under the bonnet it looked ‘tired’ and dirty but nothing that would not clean up and i’ve seen a LOT worse. On the plus side, as a 69 car, it has the quirky old ‘slab’ dash. The ID20 is the more powerful variant of the ID19 and in 1970 was re-badged the ‘DSuper’. As such, it’s like the St.Albans car but a couple of years older. For someone who knows what to expect, this could be a nice car after some work. I would estimate this is worth £4K to £5K to the right, brave person who knows what they’re doing and that feels consistent with £10K for the more solid St. Albans car.
Anyway, he then told me he had two more Ds in barns! Both LHD and both covered in a patina of heavy dust. He’d had all three cars over 20 years and these other two had not been driven/ run in quite a while. First up was a 1975 DS23 eft bvh pallas with leather interior – so top spec.
Metallic grey with black leather. It had had a cheap(ish) respray and was showing surface rust though nothing serious. No major dinks that i could see. Couldn’t see underneath. No weeds, no mould, no mildew. It was ‘complete’ – all together, and looked very respectable under the bonnet just dust and grease.
With a bit of tinkering it looked like it could be persuaded to start. Possible water pump or expansion tank leak. Efi’s can be tricky beasts and as it’s not currently a runner, i felt that would affect the value/ interest.
Next up was a 1967 frogeye ID19!
This was lovely – very original – dark blue with a white roof and a very tidy red rhovyline interior.
Like the white car it has the ‘slab’ dashboard – albeit with different style buttons and stalks and the addition of a hazard light with on the dash. The hazard light looked to be genuine Citroen type. paintwork/ bodywork very tidy. Coffin shaped tail lights (not cracked) and plastic rear indicator trumpets (not cracked).Boot clean and tidy.
No signs of rust that i remember. Couldn’t get the bonnet up so not sure if it had power steering or not. Couldn’t see underneath. No weeds, no mould, no mildew. Overall it looked very respectable and very ‘genuine’. Again, not been run in a while but should be easy to get it going as a ‘proof of concept’. i would like to think that – after a good clean and hoover – this car could virtually be used as it was. But that is what i thought about my car 12 years ago!
I’m trying to hook him up with potential sale sites/ buyers.
have you looked at images of RHD carpet sets on the sites of the big boys? i wondered if they showed the difference you expected to find with your set?
Thanks for the compliment. Paintwise, my car has never looked that smart in my entire 30+ years of ownership – so it it is a BIG improvement in my eyes. However, I have to keep managing peoples expectations. i’m not and never have been going for a concourse look. I’ll be quite happy with my car showing it’s age (and being genuine citroen parts) but i do have standards….
As do you with your seats/ door cards. As the saying goes: if you want it done well – do it yourself. That is certainly true of the lack of ‘quality control’ i’ve sometimes felt others have had when i’ve entrusted jobs to them.
carpets. Coverdale do indeed have a good reputation and, if/ when i need to ditch my original citroen carpets, they’d be the first people i’d call. i think they may apply the leatherette edge binding differently to original Citroen carpets but that is a VERY minor difference.
In my haste to get my car looking spick and span i glued my carpets on in the wrong order! I glued the carpet on box under the front seats and the carpet on the sills. Only then did i realise that i wouldn’t be able to fit the stainless ‘J’ shaped ‘hockey stick’ edges because their screws end up hidden under the carpet….
I pulled the carpet off the sills to fit the stainless stuff. THEN i discovered that the edge of the sill carpet is raw and needs to tuck under/ behind the bound edge of the carpet on the seat base. So the ends of that seat carpeting had to be pulled up to allow me to properly fit the sill carpet…
Based on my cock ups (and the binding on the original carpet) i would say the order is this….
vertical stainless (‘apron covers’?) on the sills
Metal strips with those white rubber bits to hold the vertical covers in place.
Horizontal sill covers. these are the ones that tuck in behind those white rubber bits on one of their edges
‘J’ shaped hockey stick edges to secure the other edge of the vertical sill trim
Carpet with pocket on the front bulkhead
(on my LHD bvh car, at this point I needed to put the carpet on the brake mushroom box)
carpet on the ‘A’ panels
carpet on the front face of the footwells (good luck putting the screws back through the bulkhead!
leatherette trim over the hinge of the petrol tank box lid
carpet on the front face of the petrol tank box and leatherette edge
carpet over the sills – being careful to tuck the binding edge into/ under the ‘J’ hockey sticks before the carpet glue sets.
Carpet over the seat baseBack to my point about concourse: my stainless sill covered are covered in gritty scratches and pox mark dents (high heel marks?) but i’m keeping them rather than replacing them with very expensive repros. i think a 58 year old car is entitled to show it’s age and looks more in keeping if it does. I cleaned up my white rubber bits. They look a bit off-white but again (in my eyes at least) that’s what i’d expect them to look like after nearly 60 years.
Odd that one sill piece is correct and one not! That underlay looks very neat. My car still had the citroen stuff stuck to the floor and so i left it as was.Yes – the white squashy ribbed stuff is available as repro. Here it is from Sassens:
See also Sassens part 1157b – same stuff but for back door openings.
And here it is from ‘CitroenDS’. set of four pieces:
I couldn’t find it on his website but Darrin in the UK *might* sell it?
