Viewing 15 posts - 1 through 15 (of 1,317 total)
  • in reply to: Sh*t Just Got Real….. #12956
    in reply to: Hello from Wiltshire #12901
    in reply to: Hello from Wiltshire #12897
    I feel another table coming on……
    The top table includes the 2175cc DSuper5 (‘DP’ vehicles). the bottom table is for ‘DT’ vehicles. These are the 1985cc ‘DSupers’ with the optional 5th gear.
    in reply to: Hello from Wiltshire #12895
    in reply to: Hello from Wiltshire #12894
    Where as previously there was only an ID19, in 1969 Citroen added an ID20 alongside the ID19. Both were manual four speeds with the same 1985cc engines, except that the ID20 had slightly better trim and was tuned to give a few more BHP.
    For the 1970 year, the cars were renamed. the ID19 became the DSpecial and the ID20 became a DSuper.
    After a year or so, Citroen offered an extra fifth gear for the D Super – so there were SOME 1985cc cars that were DSuper (5)s. The DS21 (2175cc) could be bought with a manual 5 speed box.
    Then in 72 or maybe 73, the DS21 was dropped from the Ds range and instead resurrected as part of the ID range – where it became the 2175cc ‘DSuper 5’. Sounds like the St.Albans car is a standard 1985cc 4 speed DSuper. Chassis tags still said ‘ID20’. All perfectly legit. It may not be a ‘DSuper5’. but it’s still a step above a DSpecial and from what Julian has said, might be worth haggling over.
    in reply to: EFI throttle linkage – reconnection #12808
    My cars a bvh, but if it was manual i wouldn’t carry a spare clutch cable up in the roof channel.
    Fitting a clutch cable is maybe a couple of hours work. Refitting the b*stard Pallas roof trim is about four!
    in reply to: EFI throttle linkage – reconnection #12806
    If it helps….
    These are four photos by Stuart McGregor that go with the text in the post above – which I repeat here. You can also find a good exploded diagram of the parts in drawing number 2-142/1 in the early pages of manual 648.
    As Stuart wrote:
    From the bottom you’ll have to undo the pinch bolt on the lever (this is a reference to the bolt through part 7 in the drawing) and pry the lever off the pedal shaft (part 1 in the drawing)…….
    …..to get to the split pin/clevis pin (Stuarts photo above shows some kind of knotted or tangled wire?) that secures the cable inner at the bottom end.
    Then from the top you need to remove the pozidrive screw that holds the clamp plate (part 5?) holding the outer in place. (near to the engine mount bolt).
    With that done remove the clamp plate and the outer will lift out.
    A telescopic magnetic picker may be your friend here! There’s a pic that shows that upper part disassembled if that helps.Getting that small clamp plate (part 5) in position and fixed on reassembly will most likely be your biggest challenge. You may be best to remove a few items that obscure it. Perhaps the weight fixed to the bulkhead and the engine mount? (In a later post Stuart said it may not be as bad as he thought and that a LONG screwdriver could be used to access the screw).
    Have included a pic that includes these two items (the phots above), though appreciate that there’s a lot of EFI hardware etc also sitting above this area.
    in reply to: EFI throttle linkage – reconnection #12805
    I recall a VERY long thread about this (throttle cable replacement on a LHD efi car) on another forum: the largely (though not exclusively) American ‘CitroenDSID’ group on a platform called ‘IO’. You could do a lot worse than seeking out that thread (and joining the forum if you really, really need to).
    This is the thread though i’m not sure you will be able to access it. The thread was called “Oh, Snap!!!”
    https://groups.io/g/CitroenDSID/topic/94635675#msg96040
    It was 82 posts long (!) and in early posts advice included:
    From Michael Faulks
    “access is tight but it can be replaced without taking the engine out. There is a clamp just above the pulley that holds the sheath and a slot in the bracket so the cable can be threaded onto the pulley. Undo the clamp and the adjuster bracket then the cable just pulls out of the engine bay.
    And from Stuart McGregor:
    “Here’s a few more pix that show the stages below.
    From the bottom you’ll have to undo the pinch bolt on the lever and pry the lever off the pedal shaft to get to the split pin/clevis pin that secures the cable inner at the bottom end.
    Then from the top you need to remove the pozi screw that holds the clamp plate holding the outer in place. With that done remove the clamp plate and the outer will lift out. A telescopic magnetic picker may be your friend here! There’s a pic that shows that upper part disassembled if that helps.
    Getting that small clamp plate in position and fixed on reassembly will most likely be your biggest challenge. You may be best to remove a few items that obscure it. Perhaps the weight fixed to the bulkhead and the engine mount? Have included a pic that includes these two items, though appreciate that there’s a lot of EFI hardware etc also sitting above this area. It’s difficult to figure that out as I don’t have an engine in my car!”
    in reply to: Hello from Wiltshire #12802
    As a South African car, they followed their own trim specification and names. The advert says it 2100cc but a DS20/5 was a 1985cc DY3 engine with a five speed box.
    https://www.citroenet.org.uk/publicity-brochures/ds/za/za-ds.html
    So a bit/ lot like the ‘DSuper(5)’ (a 1985cc DSuper but with an extra gear) but NOT like the ‘DSuper5’ (2175cc engine and an extra gear).
    The photos show a head rebuild, maybe the pots were upgraded from 1985cc but that would make it 2175cc not 2100cc?
    From the description, ownership and willingness to show photos, this might not be a bad car – but the price certainly reflects that. And be aware that it’s not just European cars: South African cars can have rust too 🙂
