https://i.ibb.co/vC2HyWB6/20260617-145725-2.jpgIIRC the sill outer plates were plain on earlier cars but were changed for square patterned ones on later cars. Mine are plain and mine’s a 1969 UK car. I think the information about it is in the John Reynolds book somewhere, if I remember later I’ll have a look.
As for why?
Possible hypotheses are:-
Good luck Mr Holmes!Thinking about it, the logical time for any modifications to be made would have been the structural improvements in 1971, there were a lot of changes made to the front end (think we discussed this in a previous post). Given that the dashboard is anchored to this area it may be that they reinforced the mounting points for it. No doubt someone knows.
Well you were right about the handbrake, the extra plate holds the mounting bracket for the top of this lever:
This is the bracket:
While I was there I looked at the epaulettes again. It looks like the later cars have the top bent over then the tab for the dashboard mounting bracket welded on top. When you hold the new part next to what’s already there you can see the top edge matches, but will need bending to suit:
So there’s a change in design somewhere after 1968. I can’t check on my car as the windscreen is still fitted. -
