John Montgomery
Viewing 15 posts - 1 through 15 (of 81 total)
  • in reply to: Festival? Bestival #13203
    in reply to: Hello from Wiltshire #13021
    IIRC the sill outer plates were plain on earlier cars but were changed for square patterned ones on later cars. Mine are plain and mine’s a 1969 UK car. I think the information about it is in the John Reynolds book somewhere, if I remember later I’ll have a look.
    in reply to: Front/Rear Loudspeaker fader control #12969
    in reply to: Front/Rear Loudspeaker fader control #12967
    in reply to: Crusty #12183
    in reply to: Crusty #12169
    in reply to: Door interior parts #12148
    in reply to: Struck gold #12141
    in reply to: Struck gold #12139
    in reply to: Struck gold #12131
    As for why?
    Possible hypotheses are:-
    Good luck Mr Holmes!
    in reply to: Struck gold #12128
    Thinking about it, the logical time for any modifications to be made would have been the structural improvements in 1971, there were a lot of changes made to the front end (think we discussed this in a previous post). Given that the dashboard is anchored to this area it may be that they reinforced the mounting points for it. No doubt someone knows.
