Cheers again.
Sorry, mine’s 1969 not 1967!
https://i.ibb.co/vC2HyWB6/20260617-145725-2.jpgIIRC the sill outer plates were plain on earlier cars but were changed for square patterned ones on later cars. Mine are plain and mine’s a 1969 UK car. I think the information about it is in the John Reynolds book somewhere, if I remember later I’ll have a look.
