https://i.ibb.co/vC2HyWB6/20260617-145725-2.jpgIIRC the sill outer plates were plain on earlier cars but were changed for square patterned ones on later cars. Mine are plain and mine’s a 1969 UK car. I think the information about it is in the John Reynolds book somewhere, if I remember later I’ll have a look.
As for why?
Possible hypotheses are:-
Good luck Mr Holmes!Thinking about it, the logical time for any modifications to be made would have been the structural improvements in 1971, there were a lot of changes made to the front end (think we discussed this in a previous post). Given that the dashboard is anchored to this area it may be that they reinforced the mounting points for it. No doubt someone knows.
