Please keep us posted Paul, this is a mod I will probably do if/when my car gets to that stage 👍
If you’re worried about PTFE getting into the block then I’d suggest using either liquid PTFE or gas tape (yellow roll). The gas tape is a lot thicker than ordinary PTFE so you need less of it and it doesn’t strand off like the normal stuff. It stays together better when you remove it too. Just don’t use too much though.
