John Montgomery
Viewing 15 posts - 1 through 15 (of 110 total)
  • in reply to: Hello from Wiltshire #13972
    Here’s a photo I downloaded of someone else’s technique for the trims (not mine):
    in reply to: Nearly There! #13961
    Please keep us posted Paul, this is a mod I will probably do if/when my car gets to that stage 👍
    in reply to: Nearly There! #13959
    If you’re worried about PTFE getting into the block then I’d suggest using either liquid PTFE or gas tape (yellow roll). The gas tape is a lot thicker than ordinary PTFE so you need less of it and it doesn’t strand off like the normal stuff. It stays together better when you remove it too. Just don’t use too much though.
    in reply to: Nearly There! #13942
    in reply to: Nearly There! #13939
    in reply to: Nearly There! #13918
    in reply to: Three dial dash #13906
    in reply to: Three dial dash #13874
