John Montgomery
Viewing 15 posts - 1 through 15 (of 89 total)
  • in reply to: Nearly There! #13391
    Car looks terrific 👍
    Washer
    Cheers again.
    Sorry, mine’s 1969 not 1967!
    in reply to: Hello from Wiltshire #13021
    IIRC the sill outer plates were plain on earlier cars but were changed for square patterned ones on later cars. Mine are plain and mine’s a 1969 UK car. I think the information about it is in the John Reynolds book somewhere, if I remember later I’ll have a look.
    in reply to: Front/Rear Loudspeaker fader control #12969
