Think it’s a good point about LHS, the cost to change a car to LHM wouldn’t have been viable for the older cars once their resale value fell below a certain point. It was just accepted back then that the life of a car was shorter due to rust or mechanical faults, Keith Would once told me the average life of a D was 8-10 years before major welding was needed? -
