This is something I would be interested in doing myself.Kind RegarDS
Citroën DS RestorationAmazing work Paul – well done.
ps. the driving lamps look great 😉Kind RegarDS
Citroën DS RestorationGrrrr rubbish!… Just out of interest if you want want to watch anything without the adverts just put a ‘dash’ (-) between the t and u of youtube like so https://www.yout-ube.com/watch?v=GydsYFLPPYc hey presto. Enjoy.
Kind RegarDS
Citroën DS RestorationPeter, this looks great. You are proceeding well, keep us up to date with photos. Well done.
Kind RegarDS
Citroën DS RestorationI’m there Saturday and Sunday, see you then Paul.
Kind RegarDS
Citroën DS RestorationGood job Julian 🙂
Kind RegarDS
Citroën DS RestorationWhen you have the complete arm assembly in the vice remove the 38mm nut and the bearing sleeve will be removed easily.
Kind RegarDS
Citroën DS RestorationLeave the 38mm nut tight in place and remove the screwed ring completely and the bearing housing will come out complete with the arm.
Kind RegarDS
Citroën DS RestorationJulian,
The arm should come out now. Believe me they are tight! you may need to drive a wedge in the gap after removing the antiroll bar clamp and screwed ring shown here…Kind RegarDS
Citroën DS RestorationHi Julian.
Short answer – Yes. The rear suspension cylinder and sphere assembly is held in place by it’s own pressure, loosen the sphere by half a turn before releasing the pressure. Failing to do so could result in a damaged feed pipe to the cylinder as the assembly may twist in the housing. When the sphere is loose depressurise the system and everything should start ‘rattling’ around. Be gentle with the feed pipe they can be fragile and use new sphere and pipe seals — Good luck.Kind RegarDS
Citroën DS RestorationHave a look at this, it may help… https://citroendsrestoration.blogspot.com/2012/11/rear-suspension.html?m=1
Kind RegarDS
Kind RegarDS
Citroën DS RestorationTry Citroen Classics https://shop.citroenclassics.co.uk/sticker-with-writing-for-fluid-reservoir-1625-p.asp
Kind RegarDS
Citroën DS Restoration… assuming you have a later type 3rd nose?
Kind RegarDS
Citroën DS RestorationHi David
You might need one of these, they get very brittle and break over time.
https://shop.citroenclassics.co.uk/end-piece-for-self-levelling–headlamp-adjust-435-p.aspKind RegarDS
Citroën DS Restoration -
