ON THE ROAD AGAIN !
That brass springy part found hanging around was indeed from the acceleration device on the carburettor. The engine started after it’s new barrels & cylinders first time but when bleeding LHM (carb acceleration device), the whole locality became filled with smoke. Turned out that there was a missing piston rod in the acceleration device. Wer had found a little rod hanging around & had employed it to plug the fuel pipe during the engine out work. It was thought to have been chucked but amazingly, it was there in a gash tray of bolts !
I say it started first time (which it did) but we had committed the schoolboy ruse of initially mixing up HT leads 1 & 2 … but it still ran … & no leaks ! Where we needed 1st gear to negotiate a hill, we were now doing it in 3rd gear.
I was obsessed with ignition timing & before replacing the cylinders, seemed to get a bit more ommpf by advancing the timing. Now all is running good, I see no reason why with Curve “B” selected on the 123 ignition module set at 12 degrees BTDC static timing, that not worth fiddling with timing light as once running, I might imagine it might be slightly more advanced than the 12 degrees. Should one trim it back to 12 degrees at tick over or reason that fuels take longer to ignite so better to have it advanced a bit etc etc. I’m leaving .. OK you think ?
Next on the list will be to look at why the front suspension does not behave as smoothly as seen typically on Youtube. Plan to remove & clean the height corrector. I also noted that when pushing down the front bumper, the RHS does not drop as far as the LHS. These welded items are about 7 years old & I wonder if they have deflated at different rates and is 7 years normal ? Intend to swap over & see if the issue follows. For the money, not worth testing … get jet new ones don’t you think (comfort spheres ID75FA 5465211COMF for ~ £124.80) from Citroen Classics ?
Whilst bleeding the LHM, I did wonder what happens to the air that is trapped due to the necessary use of the extended LHS suspension sphere. Will this air stay up there or will it continue to unset everything as it with time somehow gets back through the height corrector to eventually disappear. If I can fit the extension piece first then fill to the top with LHM, this trapped air will be beneficially gone … or will it just disappear naturally ?
WHAT A JOY … our 1968 DS21 starts on the button & runs sweet and … NO LEAKS !Thanks for all your encouragement, Michael Anselm (Isle of Wight)
Thanks Paul & thanks Peter for your guidance. We now have the liners removed (flywheel & crankshaft in position). I successfully used some threaded bar and a couple of rusty square washers that can be found next to disintegrating wooden breakwaters on the beach.
FURTHER QUESTION please
I believe the piston / liner kit are delivered with pistons fitted with rings but not inserted into the liners. I have a bespoke spring steel ring compressor that tightens up. Without thinking too much yet, my immediate thought would be to assemble the con rod to the piston & then insert the assembly down from the topside (cylinder head end) for the rings to “jump” into the liner. Could one then guide the big end bearing squarely onto the crankshaft taking care not to rotate the piston & its 120 degree angled rings. The engine block is on its side (timing gear uppermost). Will trying to insert horizontally be cursed by gravity do you think ? Ideally (?) I would like these assemblies lowered down vertically to avoid the biased gravity that horizontal insertion might create. Trouble is, it would take effort to move into such a position & I would not really delight in being under the block guiding the bearings into position(using decent a hydraulic hoist).
OPTION 2 would be to push the piston up into the liner using the ring compressor to hopefully do its thing. The compressor clearly must be tight but loose enough for a rubber mallet to allow the piston to move. This is not currently my plan as I really want sharp right angles for the rings not to break by crossing this interface.
Would be pleased to hear your views / recommendations…. especially if based on experience.
Regards & thanks,
Michael (Isle of Wight)Update From Owner: The engine/gearbox assembly is now out of the vehicle & piston/conrod assemblies popped out. Some of the previous mysteries aired on this forum are now a little clearer:
2) POWER LOSS / STARTING ISSUES: Only piston number 4 had the full complement of three unbroken piston rings. The 40 psi compression of number 1 has two of the rings snapped with damage to the piston obvious. There is a witness mark on the liner wall of number 1.Measuring the diameter of the loners, it became clear that this engine had not been converted to a 2175cc as the seller had claimed. An initial attempt to remove the liner of number 1 with a wooden block and a mallet was unsuccessful, as was number 2. An attempt using a threaded bar & a sturdy metal backing plate will be attempted in the next few days but I somehow expect not to be able to get them out with this off-the-shelf threaded bar set-up. Could do with a finer pitch I suspect. I imagine a hydraulic set-up will be required because of the loads. Youtube have loads of videos of people doing horrible things with chisels & the like to split the liner. I am guessing that the liner is stuck where it fits within a cast iron hole & the seals are not unlike piston rings.
Advice would ne Nice,
Cheers, Michael (Isle of Wight)I stand corrected …. the newly purchased rear spheres are indeed ID 40 RX … termed “comfort spheres”. All make’s sense & now so at peace with the world … PHEW !
Michael (Isle of Wight)Greetings Team DS … HAPPY DAYZ !
One phone call to Darrin of Citroen Classics resulted in the realisation that the cast splined top levers ARE HANDED. Guess what …. I refitted them the wrong way round with the apparently “unnecessary lump” outboard. Swapped over & all was good ! Obviously, I sort of wish I had not cut the 10mm off the threaded rods but quite a few threads can still be seen on the inside of the two clamps so I am sort of OK with that. The distance between the ends of the rods inside the adjuster sleave after tracking performed with wheels off ground is about 20mm so yeah … a 5mm cut would have been better. I’m thinking that the toe in will reduce at normal height.Can’t wait to get the Pallas off the chocks to bleed rear brakes & tune the tracking & checking out the new rear “comfort” spheres (didn’t know until recently that there were two types). My new comfort front spheres have a “26” in it’s code & the old ones (dated 2018) had “40”. Now I’m guessing that this is the pressure in Bar units. There surely must be a damping “orifice” difference between the two for otherwise, just stick with then 40 Bar ones & they will progressively become softer with time. Like … why wouldn’t you want the DS to be “comfortable” ? Apparently, there are “comfort ” ones for the front. Is this something I should strive to get in order to experience what the DS is famous for ?
Thanks for your support,
Michael Anselm (Isle o0f Wight)SO … I did cut off sufficient to enable all the LH/RH thread on both parts to be fully utilised to maximise toe in potential. To see if I was in the right ball park, as the vehicle is on axle stands, I jacked the suspension arms to a position where then outer track rod were about horizontal (as a nod to where the ride height might be). The steering wheel was turned so that the measurement between the wheel rim & the body both sides were the same to approximate for straight ahead direction. With the front inner wheel rims marked with chalk level with the centre of the wheel, I then measured the distance between the wheel rims at the front then rotated wheels backwards 180 degrees to hopefully note a greater distance. HE DISTANCE WAS ABOUT 25mm TOE OUT (still). I intend to use some old track rod parts to fit an adjustable (shorter) rod on the LHS per then existing RHS to (surely) produce some toe in (a 1 inch reduction in rod length). I believe the thread is M14x1.25mm pitch.
best, Michael Anselm (Isle of wight)Thanks Peter … your experience has give me some hope that I not totally out or order !
Best, Michael (Isle of Wight)19th January 2025 at 5:03 pm in reply to: On Line Restoration of Paul’s ’68 Pallas – some help please ? #10501This knowledge diversification & encouragement is worth us sharing quite a few (beers / red wine / olives and/or cheese * if ever the planets were to align) * delete as applicable.
Michael (Isle of Wight)Friends,
PS I accept therefore that my DY2 engine fitted in this 1968 DS Pallas is incorrect & am thinking that the correct engine would be a DX2 ? Will trawl the internet but can I again cheat & ask you for your thoughts ?Paul,
Great to have someone to talk to … your comments will help us mentally prepare for the ‘joy’ of refitting !Reference your answer to question 2):
My main concern was how the CRANKSHAFT oil seal is replaced. If easy we might do it …. if difficult, then what’s a few more drips on the driveway !Regarding your welcomed response to my wordy question 3)
I was hoping you might confirm that the release bearing featuring an attached tube thing is normal & that the flopping input shaft is also normal & not indicative of a shot input shaft bearing at the other (front) end. Apart from if gearbox was overfilled, are there any seals employed to prevent gearbox oil from exiting the gearbox into the bellhousing or is the design with its catchment pan & internal drain tube all there is & that lateral shaft movement is normal & not something that is a big problem when aligning gearbox to engine. Should one splash out on a custom alignment tool for the friction plate & if so … is there a good supplier for such (I know this will be the hardest thing to achieve so a few quid to make it easier is well worth it).With regard to your response to my question 4)
Sorry I wasn’t clear but I am confused as well. It is a 1968 LHD DS but fitted with a later DY2 engine (for better or worse). You did not confirm my guessed method to date the engine to 1970 via the 5th digit on the serial number but any subtleties however would anyway be lost on me.THANKS & ‘Keep The LHM Flowing’ (but hopefully not onto my drive once the split front suspension gaiters have been replaced !)
Michael (Isle of Wight)Hi Paul,
QUESTIONS:
4) How can one date one’s gearbox and engine ? The g/box has a tag on it “65 126138” and the engine S/No is 0560025147. Regarding the engine, is not the 5th digit the year .. thereby being either 1960, 1970 or 1980 … clearly be a 1970 (if this rule is Citroen-wide). The vehicle is a late 1968 Pallas 21.Thanks for any comments / assistance on the above to give me a bit of confidence as I have not done this sort of thing before. Any tips such as a method to minimise the anticipated alignment struggle would be v. gratefully received !
Best, Michael (Isle of Wight)Christopher,
CLUTCH CHANGE:
THANKS …
Michael AmselmAhoy my Goddess Lovers,
Cheers, Michael (Isle of Wight)Thanks Paul for your comments.
Thanks, Michael -
