Michael Anselm
Viewing 7 posts - 1 through 7 (of 7 total)
  • This knowledge diversification & encouragement is worth us sharing quite a few (beers / red wine / olives and/or cheese * if ever the planets were to align) * delete as applicable.
    Michael (Isle of Wight)
    in reply to: BVH Clutch Slip #9981
    Friends,
    PS I accept therefore that my DY2 engine fitted in this 1968 DS Pallas is incorrect & am thinking that the correct engine would be a DX2 ? Will trawl the internet but can I again cheat & ask you for your thoughts ?
    in reply to: BVH Clutch Slip #9950
    Paul,
    Great to have someone to talk to … your comments will help us mentally prepare for the ‘joy’ of refitting !
    Reference your answer to question 2):
    My main concern was how the CRANKSHAFT oil seal is replaced. If easy we might do it …. if difficult, then what’s a few more drips on the driveway !
    Regarding your welcomed response to my wordy question 3)
    I was hoping you might confirm that the release bearing featuring an attached tube thing is normal & that the flopping input shaft is also normal & not indicative of a shot input shaft bearing at the other (front) end. Apart from if gearbox was overfilled, are there any seals employed to prevent gearbox oil from exiting the gearbox into the bellhousing or is the design with its catchment pan & internal drain tube all there is & that lateral shaft movement is normal & not something that is a big problem when aligning gearbox to engine. Should one splash out on a custom alignment tool for the friction plate & if so … is there a good supplier for such (I know this will be the hardest thing to achieve so a few quid to make it easier is well worth it).
    With regard to your response to my question 4)
    Sorry I wasn’t clear but I am confused as well. It is a 1968 LHD DS but fitted with a later DY2 engine (for better or worse). You did not confirm my guessed method to date the engine to 1970 via the 5th digit on the serial number but any subtleties however would anyway be lost on me.
    THANKS & ‘Keep The LHM Flowing’ (but hopefully not onto my drive once the split front suspension gaiters have been replaced !)
    in reply to: BVH Clutch Slip #9940
    Hi Paul,
    QUESTIONS:
    4) How can one date one’s gearbox and engine ? The g/box has a tag on it “65 126138” and the engine S/No is 0560025147. Regarding the engine, is not the 5th digit the year .. thereby being either 1960, 1970 or 1980 … clearly be a 1970 (if this rule is Citroen-wide). The vehicle is a late 1968 Pallas 21.
    Thanks for any comments / assistance on the above to give me a bit of confidence as I have not done this sort of thing before. Any tips such as a method to minimise the anticipated alignment struggle would be v. gratefully received !
    Best, Michael (Isle of Wight)
    in reply to: No traction #9729
    Christopher,
    CLUTCH CHANGE:
    THANKS …
    Michael Amselm
    in reply to: Tuning Weber 28/36DLE2 (BVH) #9396
    Ahoy my Goddess Lovers,
    Cheers, Michael (Isle of Wight)
    in reply to: Tuning Weber 28/36DLE2 (BVH) #9387
    Thanks Paul for your comments.
    Thanks, Michael
